Forums/Z31P/z31-performance-upgrade-forums cosmetic-interior-exterior/na2t wiring issue
Imported from Z31Performance.com Forums{{#if:jm9308| — original post by jm9308}}{{#if:2013-10-19 20:11:38|, posted 2013-10-19 20:11:38}}{{#if:2| · 2 post{{#ifeq:2|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/cosmetic-interior-exterior/22790-na2t-wiring-issue.html|
jm9308: (2013-10-19 20:11:38)
Need some help from the community.
Na2t heavy stuff complete. Now when I turn it over it fires and at times barely idles below 500 and or chokes.
When I remove the mafs connector at times its starts and idles below 2k.
With 2 pins jumped at the maf connector it start easily, idles and revs like a charm. See attached pic. I apologize for the small size but it seems this new version of v5 is limited to smaller size pics.
I am at a complete loss.
Tripe checked connections, continuity, sensors, new vacuum lines and relays are good.
I am using 85 n/a harness with 87 ecu and o2 sensor. Installed the turbo idle controls and wired as described on the xenonz31 site.
Thanks Attached files
jm9308: (2013-10-27 09:03:31)
Please delete.
