Forums/Z31P/z31-performance-upgrade-forums cosmetic-interior-exterior/fender cutting advice needed
Imported from Z31Performance.com Forums{{#if:adroitcaptor| — original post by adroitcaptor}}{{#if:2014-08-10 03:26:59|, posted 2014-08-10 03:26:59}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/cosmetic-interior-exterior/24135-fender-cutting-advice-needed.html|
adroitcaptor: (2014-08-10 03:26:59)
ATM I am super high on ST springs (wheel gap for days). I have a Z32 NA subframe and coilovers to come. I need advice from ppl running low body and wide tires plz. (Right now running 17x9.5 square but thinking about 18x11 RPF1s).
I flared the fender lip out instead of in. Then I cut above the pinch weld separating the outer 1/4 panel and the inner wheel well. After working the flare out I had to 'pie cut' the inner wheel well lip as I could not stretch the metal far enough to meet the inside 1/4 panel (now flared). I think I moved the wheel well up about an inch and a half…
My 2 questions:
Do you think this will be enough clearance inside the whel well?
Shoule I cut and flatten that hump on the outside upper part of the wheel well?
thx!
adroitcaptor: (2014-08-10 16:25:35)
Anyone? Going to weld them this afternoon and would appreciate the peace of mind.
862sik: (2014-08-10 21:54:15)
I wish I could help, the forum is slow on the weekends.
adamvann3: (2014-08-12 14:37:48)
Well considering there is no identification if your care is a zenki or kouki nor front or rear fenders it is pretty hard to suggest anything.
reddzx: (2014-08-12 14:48:24)
Sounds like it was the rear on a kouki
adamvann3: (2014-08-14 14:16:28)
If thats the case then 18x11 fit without any issues under rear stock kouki fenders
