Forums/Z31P/z31-performance-upgrade-forums cosmetic-interior-exterior/digital climate control illumination!
Imported from Z31Performance.com Forums{{#if:les_joey_paul| — original post by les_joey_paul}}{{#if:2013-08-29 19:20:15|, posted 2013-08-29 19:20:15}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/cosmetic-interior-exterior/22487-digital-climate-control-illumination.html|
les_joey_paul: (2013-08-29 19:20:15)
Hey, is your digital climate control display blank?
Is it difficult to tell what is being displayed?
Odds are the bulbs behind the screen have burnt out.
But. .. have no fear! For I have happened to come across a source for these.
You require 2 bulbs( one for each section)
I've found them new for 5 $ each and I can order as many as needed.
So if you're interested please post here with the amount you'd like.
Hoping to help out the community a bit with this.
I'll post a paypal address in this post later if there is interest.
The overall price will be the 5 $ plus whatever cost to ship the bulbs to you.
shromy: (2013-08-29 19:54:15)
Nissan still sells the bulbs, just an FYI.
les_joey_paul: (2013-08-29 20:07:26)
Yes. That is the source. Lol.
It seemed to me that a majority might not want to bother seeking them out through a dealership.
Then I guess if your ACCS display isn't illuminating, just go to your nearest nissan dealership and inquire.
reddzx: (2013-08-29 22:36:41)
WOW, I never would have thought of that, Thanks man.
Mitchd03: (2013-09-01 12:31:05)
My local auto parts store sells them in 5 packs.
les_joey_paul: (2013-09-01 17:30:52)
Question for you guys. … I replaced the bulbs and presto! Display illuminates..
Can see it perfectly during the night time. But not so much during day light hours.
Is there a way to adjust brightness on the display?
edwin86z: (2013-09-10 10:13:11)
I ended up taking mine apart and soldering leds to the board. And to your question, I'm not in the Z right now, but above the display window, there should be a small button for the manual defrost override button, and right next to it, I think was the adjuster for the brightness. Just find a small flathead screwdriver and adjust away!
les_joey_paul: (2013-09-10 11:56:26)
Consulted my owners manual. That adjuster is to change the air temp between the feet and dash registers. Only works at below 60º or something like that lol.
