Forums/Z31P/z31-performance-upgrade-forums cosmetic-interior-exterior/Tail lights stuck on.
Imported from Z31Performance.com Forums{{#if:'84z31| — original post by '84z31}}{{#if:2013-10-26 18:51:55|, posted 2013-10-26 18:51:55}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/cosmetic-interior-exterior/22847-tail-lights-stuck-on.html|
'84z31: (2013-10-26 18:51:55)
I went to start my car one morning 2 weeks ago and it was flat out dead. I had it jumped later and all was well. I happened to notice that once the car was turned off that the tail lights remained on. I detached the sensor and sure enough it was toast. So I just purchased a replacement one and attached it and same problem, tail lights turn on the second they are plugged in. What's the catch? I don't have a clue what to do. Any suggestions would be great.
mizagyu: (2013-10-26 19:33:24)
Your switch on the brake pedal need either adjusted or replaced. ()when the sensor box is disconnected it completely disables the rear lights, regardless of the brake pedal position.
reddzx: (2013-10-26 21:32:00)
There a little round plastic button that the switch on the brake pedal contacts. They break and fall out and the brake lights stay on
'84z31: (2013-10-27 16:58:51)
Sweet guys, thanks for the replies. I checked under the steering wheel and found the broken rubber stopper. I had read about this along time ago and had forgotten about it. My cruise control has never worked either so now I'll get that fixed at the same time.
Twisted`Z: (2013-10-28 01:28:56)
Google is your friend for common Z31 issues. If you're tight on cash duct tape and a penny will do the trick. http://z31.com/repairs/brakepedal/
KevinA: (2013-10-28 20:39:11)
+1
