Forums/Z31P/z31-performance-upgrade-forums cosmetic-interior-exterior/Ignition switch
Imported from Z31Performance.com Forums{{#if:Augustus Maximus| — original post by Augustus Maximus}}{{#if:2013-12-19 12:27:31|, posted 2013-12-19 12:27:31}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/cosmetic-interior-exterior/23086-ignition-switch.html|
Augustus Maximus: (2013-12-19 12:27:31)
Just how hard is to swap this thing. How do you pull those headless bolts.
Z_Karma: (2013-12-19 19:26:26)
I used an easy-out to back out the screws on one and just drilled the heads out on another.
Putting a little penetrating lube in there should help them back out.
They're not torqued in there incredibly tight but any thread corrosion can make it a pain in the ass.
I replaced them with some stainless socket head cap screws from ACE hardware, M8 i think is the thread, possibly M6
reddzx: (2013-12-19 21:39:25)
I drill a small eight inch deep hole in them and tap a square drive screw driver in and just turn them out.
flatfoot: (2013-12-20 03:46:38)
I've yet to do one on a nissan.
I've done a few toyotas at work. Just used a die grinder with a cutoff wheel to cut slots in them and used a custom flat screw driver with a wrench attached to it for leverage.
The replacement bolts are break to torque. You just keep tightening them until the heads break off.
Augustus Maximus: (2013-12-20 12:58:06)
I grabbed the steering column with switch attached and swapping the column is starting to appear more appealing than drilling out two ignition switches. Thanks guys.
Big Slappy Z: (2013-12-23 23:38:41)
you just cut a notch so you can fit a flathead screwdriver in there. They aren't torqued very tight. There's a video/guide somewhere online I remember watching. I didn't swap mine out because I didn't feel like pulling the dash again to get to it.
