Forums/Z31P/z31-performance-upgrade-forums cosmetic-interior-exterior/Dash replacement electrical Gremlins
Imported from Z31Performance.com Forums{{#if:Charles84AE| — original post by Charles84AE}}{{#if:2014-02-01 00:57:27|, posted 2014-02-01 00:57:27}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/cosmetic-interior-exterior/23273-dash-replacement-electrical-gremlins.html|
Charles84AE: (2014-02-01 00:57:27)
I have an 84 50th AE and I replaced my dash with one from an 85 or 86 (can't remember, I've had it awhile). Everything connected fine. I noticed that my combination switches aren't working. When I turn on the lights only the left combination switch (headlight up/down, hazard, cruise control) illuminates and the other side doesn't. My headlights come on but do not raise up (on the down position). I checked the bulbs and relays. Is the wiring harness different from later than 84? I got rid of my old dash but kept the wiring harness. Should I pull the dash again and replace the harness or could it be something else.
Thanks.
Charles (919)423-3286
sir420: (2014-02-01 14:21:05)
Could be faulty connections. Check and clean all electrical connections. Also clean the combination switch. Dash harnesses should be the same for 85 as an 84.
sir420: (2014-02-01 20:32:47)
I am also in Fayetteville NC.
