Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/vg30e weight?
Imported from Z31Performance.com Forums{{#if:SATAN| — original post by SATAN}}{{#if:2006-10-28 04:50:04|, posted 2006-10-28 04:50:04}}{{#if:12| · 12 post{{#ifeq:12|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/981-vg30e-weight.html|
SATAN: (2006-10-28 04:50:04)
450lbs just a guess. but I wann see how close I am when people chime in.
FlawleZ: (2006-10-28 04:58:25)
Well it varies with what accessories, etc. you have on the engine, but my W Series NA motor with alternator, power steering, etc. weighed just under 300 lbs.
SATAN: (2006-10-28 05:02:54)
[quote]FlawleZ wrote:
{{#if:SATAN|SATAN wrote:|Quote:}}
Holy shit! are you serious? that seems way low for some reason. thought the block alone weighed somthing like 100-150 supposedly?
MrwassmanNA2T: (2006-10-28 05:10:46)
well the two heads easily wiegh 100 lbs with everything in them
SATAN: (2006-10-28 05:34:28)
then you got the block=100 roughly
crank = 30-40
manifolds+crossover=20-30?
flyweel 20
rods and pistons=20?
intake mani and plenum=10?
balancer,alternator,power s. pump, ac comp and bracket, water pump, valve covers and oil pan, and TB=65-85?
thats roughly 375 on the low side.
FlawleZ: (2006-10-28 16:47:19)
  • shrugs*
I've got my shipping receipt from when my motor arrived from Conway freight. Who knows, their scales may have been a bit off. Reguardless, someone needs to weigh a VG30 for reference.
OR-Zman: (2006-10-30 03:34:07)
Ill weigh my engine later this week once I get it pulled. Will post up when I have the numbers. :wink:
Lance: (2006-10-30 04:22:02)
fedex told me my vg30 with everything except accessories weighed close to 500 .lbs.
Az4u2c: (2006-11-11 19:56:28)
I have an 87 engine hanging on a stand back home. Maybe i'll find a way to weight it.
Jason84NA2T: (2006-11-13 01:03:07)
The VG30E is under 300lbs without acessories… the ET is a little more with the turbocharger. The heads are actually around 32lbs each assembled (based on shipping weight).
FlawleZ: (2006-11-13 02:41:49)
Cool. So I was pretty close anyway.
MrwassmanNA2T: (2006-11-13 05:51:57)
No way, only 65 lbs for both of them? Mine must just be reaaaaaallly dirty. [archived image: biggrin.png]
