Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/timing belt movement
Imported from Z31Performance.com Forums{{#if:xanmanz31| — original post by xanmanz31}}{{#if:2013-10-24 07:52:33|, posted 2013-10-24 07:52:33}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/22828-timing-belt-movement.html|
xanmanz31: (2013-10-24 07:52:33)
just finished timing belt and NA2T noticed my timing belt has moved back almost against the rear timing cover. cams and crank are tight tensioner isnt too tight. i also flipped it around so the arrows pointed out .
any ideas?
G-E: (2013-10-29 00:29:26)
Do you have those tapered washers on both sides of the crank sprocket?
Augustus Maximus: (2013-10-30 18:48:38)
Reading and attenion to detail will always be your friend. Get a manual and read it. Timing belt is rudimentary.
xanmanz31: (2013-11-18 07:50:36)
just washers on outside sprocket straight to cam
i think it ended up being loose sprocket bolt as retarded as i look ill admit it. i was just getting in a hurry i wanna drive it so bad.
after i tightened it i was able to start it fairly easily and then the dreaded oil seepage from exhaust manifold. im doing intake valve seals now.
