Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/swapping z31 t-5 to 30a
Imported from Z31Performance.com Forums{{#if:Cesar H| — original post by Cesar H}}{{#if:2013-12-20 17:44:01|, posted 2013-12-20 17:44:01}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/23091-swapping-z31-t-5-to-30a.html|
Cesar H: (2013-12-20 17:44:01)
Hey guys, Just wanted to know for those of you swapping your T-5 transmission found in early Zs to the 30a found in the older turbo models 87-89 do you guys also change your electronic speed sensor. Of course this is for those with the digital dash cluster.
michaelp: (2013-12-24 15:34:17)
So 87-89 is older than 84-86 now? :P They'd be newer. But that aside, you don't need to change any speed sensor. Just screw the speedometer cable/sensor into the drive and be done with it.
Son of Lars: (2014-01-16 04:26:37)
I asked a similar question about swapping speedo cables between auto and manual, but it appears it was in the wrong forum?, so it was deleted before I read the replies.
Cesar H: (2014-01-16 19:17:44)
Ok so then I did not need to buy anything I could use all my 90a comoponents? I have both 30a and 90a pinion gear assemblys
