Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/rb25det question
Imported from Z31Performance.com Forums{{#if:87_Z31| — original post by 87_Z31}}{{#if:2011-05-26 19:04:10|, posted 2011-05-26 19:04:10}}{{#if:9| · 9 post{{#ifeq:9|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/14543-rb25det-question.html|
87_Z31: (2011-05-26 19:04:10)
Can a stock 87 300zx manual transmission mate to a Rb25det block, is it possible to switch over bell housing's?
nismopu: (2011-05-26 19:13:08)
I think all rb25's came with a r30a variant like the 87-89 300zx turbo and n/a 300zx's came with fs5w71c's as did rrb20's I believe. Sooooo, it depends which transmission you have and which one came with your rb. Fs5's swap with other fs5's and r30a's swap parts with oother r30a's.
Careless: (2011-05-26 19:28:55)
z32 transmissions work with RB bell housings.
z31 R30A bell housings work with z32 transmissions.
therefore, rb transmissions should work with z31 R30A bell housings.
87_Z31: (2011-05-26 19:39:26)
so this is a dumb question… r30a tranny is a non turbo vg30e tranny correct?
87_Z31: (2011-05-26 19:47:07)
Nevermind I looked it up and I think I have a FS5W71C. Can you mate a bell housing to fit the FS5W71C from a R30A?
Careless: (2011-05-26 19:47:54)
FS5R30A is the designation for the TURBO 04/87+ cars.
nismopu: (2011-05-26 19:56:36)
.................................................. .................................................. ........ maybe english is a second language for you?
You cannot missmatch between the two entirely different tranny's. I explained that above.
Careless: (2011-05-26 20:28:53)
[quote]nismopu wrote:
{{#if:87_Z31|87_Z31 wrote:|Quote:}}
you didn't say they cannot be switched, you just said 71c's go with 71c's and 30a's go with 30a's.
no indication of what's not possible :-P.
he can read fine.
Racinjitter: (2011-05-27 21:47:20)
For a 71c, you need a rb20det/rb20de or a rb25de trans. For a 30a, you need a rb25det trans.
No the RB bellhousing will not bolt up to a VG30E/T and no a VG30E/T bellhousing will not bolt up to a RB.
