Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/oil pressure size
Imported from Z31Performance.com Forums{{#if:300zxturboftw| — original post by 300zxturboftw}}{{#if:2013-09-16 04:42:06|, posted 2013-09-16 04:42:06}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/22609-oil-pressure-size.html|
300zxturboftw: (2013-09-16 04:42:06)
Does anyone know size of oil pressure sending unit? M10 x 1.0? Seems the innovate one I bought is 1/8th pt
G-E: (2013-09-16 05:10:13)
1/8" bspt
300zxturboftw: (2013-09-16 05:30:01)
Ahhhhh…ok! That makes sense. Time to buy an adapter. I see some people say they restrict readings from being as accurate because its not a direct path with the fittings versus tapping the block. Sounds like a bunch of horseshit to me, but anyone else hear this?
Z_Karma: (2013-09-16 05:34:42)
It is horseshit, pressure is pressure. 40psi will still be 40psi a few millimeters away from the block. You can enlarge the hole in the adapter but the reading will be the same.
edit:
1/8th npt should thread into 1/8" bsp, but not far in enough for a good seal.
300zxturboftw: (2013-09-16 05:44:25)
28 vs 27 TPI. Not worth stressing the threads on the sensor.
I have the subaru set up with a AN braided oil hose connecting the pressure sensor about 5 inches away. Still works great, but meh who knows.
shromy: (2013-09-16 14:40:12)
ASCO has the adapter. buy it
300zxturboftw: (2013-09-16 16:02:02)
Aha! I remember seeing that there now. Already bought one from JEGS though as they have 1 day shipping to my house.
