Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/downpipe studs
Imported from Z31Performance.com Forums{{#if:pizza boys Z| — original post by pizza boys Z}}{{#if:2009-03-26 00:27:05|, posted 2009-03-26 00:27:05}}{{#if:9| · 9 post{{#ifeq:9|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/6999-downpipe-studs.html|
pizza boys Z: (2009-03-26 00:27:05)
i just installed a cm downpipe, but the stock studs are too short. how do i swap these out for longer studs? do they pound out like a wheel stud or do they turn out like a head stud?
Allout: (2009-03-26 01:43:03)
They're threaded like a head stud or an exhaust manifold stud.
pizza boys Z: (2009-03-26 02:01:20)
alright thanks alot, i just didnt wanna go under there and start messing stuff up.
mace350: (2009-03-26 15:54:29)
There are tools to remove studs…you will see why. Good luck.
DeleriousZ: (2009-03-26 15:58:08)
double bolt trick!!
pizza boys Z: (2009-03-26 20:36:36)
whats the double nut trick? put one on, and back it against another one to remove the stud?
DeleriousZ: (2009-03-26 20:55:16)
yep, you even called it by the right name lol.
pizza boys Z: (2009-03-26 21:12:49)
yea, im not a noob haha, just wanted to make sure before i screwed it up.
mace350: (2009-03-27 15:11:17)
Might be easier to weld a nut on in that location…Then you wouldn't have to heat :-)
