Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/cheap high compression pistons?
Imported from Z31Performance.com Forums{{#if:Zedman| — original post by Zedman}}{{#if:2008-03-24 10:39:21|, posted 2008-03-24 10:39:21}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/4523-cheap-high-compression-pistons.html|
Zedman: (2008-03-24 10:39:21)
Does anyone know a cheap alternative for some higher compression pistons for a na build looking for about 12:1** compression? Looking to spend under $500
Matt89: (2008-03-24 13:19:56)
Cheap?? You could always get some high temp jbweld and pour it through the spark plug hole. Make sure to measure right so you get even compression accross all cylinders.
DISCLAIMER: If you try this i am not responsible for the consequences of this high performance engine mod.
NIVO: (2008-03-24 14:40:02)
A high compression build and you want 12:1 pistons but under $500? I know where this is going.
its gonna cost u twice that if you go with Z32 Non Turbo pistons and rods, but still you will not get the 12:1.
Zedman: (2008-03-25 00:01:00)
i was just wondering whether you could get some pistons etc from another engine that will boost it up for that price, don't need it brand new or anything,
BTW: say i put z32 na pistons in it and a copper head gasket, what would you thyinhk it would set the compression to roughly, any real performance gains???
XiOus271: (2008-03-25 00:58:03)
Generally from what I have seen, most Z31's running Z32 pistons generally work out to say… 9.5:1 in a Z32 but somewhere in the neighborhood of 8.0-8.5:1 on a Z31. Do not go cheap with bottom end parts, do it right the first time, get decent parts.
G-E: (2008-04-01 07:48:29)
how about unequivocally stating the obvious, 12:1 will require some serious effort on the pistons
