Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/cams springs and valves
Imported from Z31Performance.com Forums{{#if:MuhKaydenZ| — original post by MuhKaydenZ}}{{#if:2011-11-11 22:00:44|, posted 2011-11-11 22:00:44}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/16076-cams-springs-and-valves.html|
MuhKaydenZ: (2011-11-11 22:00:44)
I need to replace the cams in the vg33 with ones fron the vg30 now the guy I bought my vg30 from said he replaced the cams (mild regrind), schneider springs, and vales (3 grind valves) as well as redoing the valve seats can I use those or should I just get some oem ones? not too farmiliar with regrinds thanks!
shromy: (2011-11-11 22:07:19)
You can use them, but you will need to have the valve seats in the 33 head cut for the 3 angle job.
88sinZ: (2011-11-13 00:39:34)
info on the differences? AllData listed them as the same, that's why i ask
shromy: (2011-11-13 00:44:18)
When you do a 3 angle valve cut the seat also needs to be cut for the 3 angle job. since his 33 heads are stock they have the stock angles cut into them.
88sinZ: (2011-11-13 00:45:42)
disregard, i skimmed the post and missed that..
