Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/bottom end rebuild parts…again
Imported from Z31Performance.com Forums{{#if:jn1cz| — original post by jn1cz}}{{#if:2008-02-28 02:35:55|, posted 2008-02-28 02:35:55}}{{#if:1| · 1 post{{#ifeq:1|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/4327-bottom-end-rebuild-parts-again.html|
jn1cz: (2008-02-28 02:35:55)
I finally ordered the rest of the parts to rebuild the new block for the shiro. I lost my original list that I put together. I had more time for research and fiche work on that list so I thought I'd post the order and see if anybody can spot anything I'm missing. I know some of these are head parts [archived image: wink.png]
Some info to avoid obvious questions:
I didn't order all new head bolts because I thought the old set was fine…but I used some of them for another project…hence the 12 bolts ordered.
Parts I'm re-using or already bought:
practically new auto tranny turbo oil pump from the old block. I did clean it thoroughly.
The old JE pistons w/ new rings (thanks Satan) and the z32 rods
the old crank and oil pan
Qty Part#
12 12113-02P00 rod bearings
2 12230-40V63 main bearings
1 12261-40V63 main bearings
1 12214-40V13 main bearings
8 11056-V5004 short head bolts
4 11056-21V02 long head bolts
1 11062-01P10 THERMO GASKET
1 15066-89E01 GASKET OIL PUMP
1 15059-V5001 O RING
1 15132-V5001 VALVE-OIL REGLT
1 12279-AD205 OIL SEAL-CRANK
1 11121-14Y10 SEAL OIL PAN
1 11121-14Y00 SEAL OIL PAN
12 11021-D0100 PLUG
1 12205-40F00 PLUG-CRANKSHAFT
1 01648-00091 PIN-CRANKSHAFT
24 13210-01M01 COLLET VALVE
6 13206-D0200 SEAL-VALUE IN
6 13206-2300A SEAT-SPRING
