Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/Z31 fan shroud
Imported from Z31Performance.com Forums{{#if:Sailingary77| — original post by Sailingary77}}{{#if:2015-07-04 18:52:10|, posted 2015-07-04 18:52:10}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/25171-z31-fan-shroud.html|
Sailingary77: (2015-07-04 18:52:10)
I've got an 85 non turbo and having trouble with the fan shroud , I had my Rad serviced and just can't get the dam shroud back in properly , seems that it needs some fasteners on the sides ?? Any advice ? Thanks and happy 4th to all
1artworkz: (2015-07-04 19:51:38)
Maybe Metric Speed Clips?
https://www.belmetric.com/metric-scr…-c-10_126.html
boosted300: (2015-07-04 23:45:03)
Oh that site is GOLD!
Sailingary77: (2015-07-05 06:16:13)
Thanks I'll give them a try , look perfect . I had my fan eating away at the shroud which ended up in a bent water pump shaft , replaced everything including the timing belt and ended up with the big washer that goes on the crank shaft to hold the belt in place , left off .. 😕 it's been running fine for a few months without that washer , should I need to worry about that , it's a total pain in the ass to take everything apart again but if it's gonna cause me more problems down the road ? Please advise thanks much
1artworkz: (2015-07-05 14:27:31)
I got most of my black split loom from them. The did not have 7/8" … had to get it on Amazon.
Sailingary77: (2015-07-05 16:28:00)
So is it a big problem not to run with the timing belt retainer washer that goes on the crank shaft ?
Sailingary77: (2015-07-23 13:44:12)
Any help
amreboot: (2015-07-23 15:08:49)
Its there for a reason.
