Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/Wideband Sensor
Imported from Z31Performance.com Forums{{#if:sp3cialfx| — original post by sp3cialfx}}{{#if:2021-01-23 10:18:03|, posted 2021-01-23 10:18:03}}{{#if:2| · 2 post{{#ifeq:2|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/545756-wideband-sensor.html|
sp3cialfx: (2021-01-23 10:18:03)
Can I put my Wideband O2 Sensor in the stock location and remove the stock sensor? Will the Wideband get a good reading there? Will it burn up there?
88sinZ: (2021-01-24 03:09:42)
Probably not, ideally you want it 18"-24" (45-60cm) after the downpipe. Fitment will depend on the sensors thread and bung
Even then, there's not much use for one unless you are going for tuning the ECU or stand alone management systems
