Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/Replacing The Heads On 84 Turbo
Imported from Z31Performance.com Forums{{#if:greedy13nk| — original post by greedy13nk}}{{#if:2008-03-21 16:35:33|, posted 2008-03-21 16:35:33}}{{#if:2| · 2 post{{#ifeq:2|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/4507-replacing-the-heads-on-84-turbo.html|
greedy13nk: (2008-03-21 16:35:33)
So I just picked up my new rebuilt set of heads with cams and valves etc. what else will i need to replace when replacing the heads i know i'll definitely need head gaskets what other things will i need to buy?
datsunzcar84: (2008-03-21 23:50:05)
Get your self a good quality "Head Set", not Felpro they IMO are junk.
You should also consider doing the timing belt, timing belt tensioner , water pump , and cylinder head temp sensor while you have it apart .
