Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/Rear Fog Lamps
Imported from Z31Performance.com Forums{{#if:TearingRaven| — original post by TearingRaven}}{{#if:2009-06-10 23:51:45|, posted 2009-06-10 23:51:45}}{{#if:9| · 9 post{{#ifeq:9|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/7619-rear-fog-lamps.html|
TearingRaven: (2009-06-10 23:51:45)
As some of you may know, there are sockets on the 87-89 center tail light piece for rear fog lights. I will be performing this modification fairly soon and was curious if there is any online documentation of this mod or existing units that may be helpful to me.
DeleriousZ: (2009-06-11 01:25:32)
i think tearingraven has a super comprehensive procedure in his build thread.
michaelp: (2009-06-11 02:24:11)
TearingRaven made this post asking, you're thinking of Taris Blue :P
Taris Blue: (2009-06-11 03:46:01)
viewtopic.php?f=13&t=14330&start=18
page 2 has my euro-fog to brake lamp conversion write-up…hopefully it will help you a little if you are planning on doing a full on rear fog setup.
floridaZ: (2009-06-11 06:30:26)
Grab a couple junk brake lights with the red covers broken. That way, if you do turn them into brake lights, you can add the light diffusers. The 87+ lights don't have enough similar material which is why I recommend getting two of those suckers. Taris Blue's pictures don't really accurately show how different from the regular brake lights they look without it.
DeleriousZ: (2009-06-11 07:26:55)
hahaha oh man, i really need to stop going to bed at 7am. you're correct.
TearingRaven: (2009-06-11 07:41:16)
Doh!
No more than 10 minutes ago did I see Taris Blue's write up, which is very well done. Kudos to you sir!
Another Question: Is a stock replacement for the butyl holding the lights on available? I would rather avoid an aftermarket measure.
Taris Blue: (2009-06-11 14:02:49)
Actually the center light section has no butyl sealant on it, only the rubber body gasket so you've got nothing to worry about in terms of sealing issues.
khyronzx: (2009-06-16 03:45:34)
aftermarket stuff works just fine.
