Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/Na2t iacv
Imported from Z31Performance.com Forums{{#if:1986z| — original post by 1986z}}{{#if:2013-12-24 19:55:22|, posted 2013-12-24 19:55:22}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/23110-na2t-iacv.html|
1986z: (2013-12-24 19:55:22)
When turboing an na is it necessary to
1986z: (2013-12-24 19:59:51)
Switch to the turbo iacv? I know you can rewire it to work. I'm just wondering if there are any differences other than the wiring.
xanmanz31: (2013-12-25 05:09:05)
it helped me to have one. i couldnt get it to run prior
matt85turbo: (2013-12-27 03:44:50)
Just ditch it. Flip the idle set screw upside-down and set the idle with that. Or tighten the throttle cable to where you want the idle.
xanmanz31: (2013-12-27 05:14:15)
its needed to pass emissions testing also i believe.
