Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/Manual Conversion
Imported from Z31Performance.com Forums{{#if:88fairlady| — original post by 88fairlady}}{{#if:2014-02-14 01:11:29|, posted 2014-02-14 01:11:29}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/23313-manual-conversion.html|
88fairlady: (2014-02-14 01:11:29)
OK so following some advice given, I am doing a Manual conversion on my 88 NA. The donor car is a 85 NA. (Have engine out) Reading some guides, they say to make sure you use the transmission from the same model car. All NA's had the same transmission, didn't they? If so, I should be fine?
My second question is regarding NA2T. After the manual conversion I will be doing NA2T as soon as I can source all the part. So after the manual conversion I will still have the 88 auto ecu in the car. Now, should all the turbo parts I need, be coming from a 85 turbo? If yes. Whats the problem I hear about 85t ecu's? If they cause problems, what should I use.
Last question is just some advice on what extra things you think I should do during the conversion.
Yes, I am a "noob", so if you took the time to even read my post. I thank you
As always, any help is greatly appreciated.......Thanks
Filipe: (2014-02-14 01:26:11)
This should answer questions about the ECU.
http://www.redz31.net/pages/fuel.html
I might need an exterior trim piece from the donor if you don't mind.
88fairlady: (2014-02-14 01:33:01)
Thanks
So I should use my same ecu then?
And you can come pick it up in a week or so
