Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/Larger throttle body on my VG30E
Imported from Z31Performance.com Forums{{#if:rex2285| — original post by rex2285}}{{#if:2008-08-30 15:54:33|, posted 2008-08-30 15:54:33}}{{#if:21| · 21 post{{#ifeq:21|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/5521-larger-throttle-body-on-my-vg30e.html|
rex2285: (2008-08-30 15:54:33)
Hey guys, does anyone know if I can put a 240sx throttle body on my 84' 300zx VG30E n/a. My throttle body now looks like it has 2 throttle cables and the 240sx throttle body has 1? Any info. will be great. thanks
Matt
LuZZifer: (2008-08-30 16:59:49)
Here you go....http://z31performance.com/forum/search.php
zmech: (2008-08-31 16:21:00)
z
badboyz31: (2008-08-31 16:29:01)
or if you don't use ur cruise control, you can shed the extra pounds and remove the unit and get the 240sx TB and ur set, but they also have a 240sx TB that has both of the cruise and throttle cables.
ZFARSI: (2008-09-02 00:20:47)
Why would he want to put a throttle body from a car with a smaller engine? The 240sx has a smaller displacement type engine?
NissanEgg: (2008-09-02 01:02:40)
Search my friend, search.
The 240SX tb is 60mm in diameter whereas the Z31 tb is 54mm in diameter. It is pointless to put it on unless you also make the inlet on the upper plenum 60mm to match.
LuZZifer: (2008-09-02 01:10:13)
It is a larger throttle body than on the Z. That means it is less restrictive and can flow more air per minute and it would improve performance.
here's some info to read. 2/3's of the page down has Throttle body upgrade.
http://redz31.suomiz.net/turbofaq/tu…q.htm#advanced
NissanEgg beat mewith fast fingers, but here's the link above to help.
I can't believe I said that above. NissanEgg did not "beat me," he simply was quicker in his response.
rex2285: (2008-09-02 01:26:09)
Hey thnx guys. Nissanegg to be honest I never thought of that, I guess I could bore it out. Turns out my exhaust is half 3" from where the cat use to be back and the rest stock, have to change that when I put on headers
rex2285: (2008-09-02 01:28:32)
thnx reborn, good info
ZFARSI: (2008-09-02 01:30:12)
So possibly the 240sx engine design needed this? Its 2.4 liter displacement has the 4 cylinder of each having 0.6 liter? So, the Nissan VG engine type having the six cylinders individually displacing 0.5 liter each. That is the math fact?
The individual cylinder mathematica can be expressed as 51mm/(0.5L/0.6L)=61mm? A relationship between cylinders has made a correlation?
88sinZ: (2008-09-02 01:43:12)
^^ you remind me of Crowbar
ZFARSI: (2008-09-02 01:49:06)
Is that a mathetica Program? Is it Freeware?
zmech: (2008-09-02 02:12:26)
z
LuZZifer: (2008-09-02 02:18:46)
Aahhh, it's LuZZifer if you want to shorten it. reborn is simply used because all my LuZZifer IDs have died and gone when I stopped posting. I started posting on ZCAR.com, twinturbo.net & lurking Z31 back in '97-98 when they all started coming online and I couldn't keep up because of work since 2003, but I am able to come back to the passion now.
I'm an old Inline Z guy that is just learning about this model and what to do with it.
and ZFARSI, I think you are missing the true engineering, mechanical, full quantum physics of how the world works within the Z motor on a universal plane.
It is the angle of the dangle that is indirectly proportional to the cosign of the amount of splash that is important. All else is irrelevant as to why the KA24 has a 60mm TB.
ZFARSI: (2008-09-04 22:11:15)
actually the math should use the area since the flow can be related to that.
So for a 54mm (is this correct?), it works out to…
[54/2]^2x3.14=22.89 sq cm
..and 60mm..
[60/2]^2x3.14=28.26 sq cm
It is still a very close correlation once 22.89*1.2=27.46 which is very close to 28.26
The more rigerous approach would subtract out the cross butterfly dimension.
88sinZ: (2008-09-05 01:10:15)
balls are touching
ZFARSI: (2008-09-05 13:01:11)
I am not that familiar with the twin throttled cars. My own Maxima is the same as the Z cars V6. I know there is another type of Maxima with two butterflys. Next to one another in an arrangement…Is this what is meant by 'balls touching'?
NissanEgg: (2008-09-06 02:39:05)
lol:
At least we know who to turn to for the math. I know the math, but too lazy to actually do it.
ZFARSI: (2008-09-06 03:40:13)
OK I just don't understand some PM
Dats Z: (2019-01-10 01:05:45)
Does anyone know if I can put an NA throttle body on my turbo Z31 ? Since it's hard to find for throttle body that comes from a turbo Z
dbruce: (2019-01-10 18:51:10)
just need to match the 60mm tb to the machines intake mani … ie get your dremel tool out … and connect your throttle cable …
