Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/Inner CV boot for SS axles
Imported from Z31Performance.com Forums{{#if:Z_Karma| — original post by Z_Karma}}{{#if:2016-03-08 18:36:44|, posted 2016-03-08 18:36:44}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/25646-inner-cv-boot-for-ss-axles.html|
Z_Karma: (2016-03-08 18:36:44)
I'm having a hard time finding a boot that will fit over the inner CV joint for my SS halfshafts.
The inner bearing housing (90mm OD) has a raised 94mm OD lip. This differs from the outer bearing
housing which has a no raised lip, but a indented channel. Like this photo from hybridz:
The BeckArnley 103-2513 works great on the outside but when stretched over the inside, does not
stretch over that raised lip far in enough to get the clamp on.
Same thing with Dorman boots (614-001, 614-002).
Before i grab ankles and buy OEM, has anyone found a suitable replacement for the inner CV boot?
Thanks.
Z_Karma: (2016-03-09 03:12:35)
Think i answered my own question with some research, but will post it here for posterity.
The OEM solution is a no-go as the part numbers for the boot kits show as unavailable,
sure there may be a few out there collecting dust.
EMPI makes CV boots and more importantly, has control drawings on their site.
http://www.showmetheparts.com/empi/
Rear Inner: PN 86-2127-D
[archived image: JYwkpta.jpg]
Rear Outer: PN 86-1170-D
[archived image: sIffGPV.jpg]
None of the local places carry them (Autozone,Oreilly,NAPA,Autovalue network)
But, JC Whitney (the granddaddy of DIY performance) carries them:
http://www.jcwhitney.com/empi-oe-rep…1663y1988g30j1
Augustus Maximus: (2016-03-11 06:06:35)
Inner boot meaning diff side? If so Beck/arnley fits and looks exactly like OEM.
Z_Karma: (2016-03-11 06:43:21)
Yeah, diff side.
The BeckArnley that i got only work on the wheel side,
although they say inner and outer in the application.
I got the ones from JCWhitney coming next week.
No stress, just want to get them finished and off the bench so i can start the camber mod for the crossmember.
Shit that leaves my bench in an unfinished state has a tendency to stay in that state for an extended period.
Z_Karma: (2016-03-15 03:46:21)
So the EMPI boots fit much better. Where as the BeckArnley had to be stretched and fit short, the EMPI was a perfect fit.
The BeckArnley are still nice and fit fine on the outside.
Augustus Maximus: (2016-03-15 13:04:55)
Hold it, obviously the SS axle is stouter than the regular turbo axle. I'll snap a pic.
Augustus Maximus: (2016-03-15 13:05:44)
[archived image: 20160315_085201_zpsag89oyux.jpg]
That's it on the diff outer side
Augustus Maximus: (2016-03-15 13:12:33)
12hrs on the job got me messed up. You're right, I have yet to do the inside. I guess I'll be needing a set of EMPI boots.
