Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/Injector clip retainers.
Imported from Z31Performance.com Forums{{#if:JN210| — original post by JN210}}{{#if:2011-05-06 16:40:45|, posted 2011-05-06 16:40:45}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/14300-injector-clip-retainers.html|
JN210: (2011-05-06 16:40:45)
Si im not sure where all 6 of mine went…any ideas for replacement? I really dont want to run with nothing holding my clips on my injectors, I was thinkin safety wire around them nice and snug. nowhere else in town has what im looking for.
Careless: (2011-05-06 16:54:26)
orrrrrrr you could buy them from nissan. they're a separate part number from the plastic clip itself.
michaelp: (2011-05-06 17:19:36)
I'd replace all 6 of the connectors with quick release ones off a GM.
JN210: (2011-05-06 17:22:51)
O rly? Do you know what that number is? I tried getting them from my dealership and they couldnt find them. and what are the quickreleases you speak of?
edicer2: (2011-05-06 17:24:21)
whats the quick release ones off of?
superfast300: (2011-05-06 17:29:28)
I just went to the junk yard yesterday and got 6 injector clips off of 2 non turbo eclipses they are the ones that just click on and you can take them off by pressing the sides in real nice if you can do it. O and they were 2nd gen eclipses they fit right on factory injectors
JN210: (2011-05-06 17:35:20)
id really rather not do alot of hack and solder on my harness…lol
Z_Karma: (2011-05-06 17:57:18)
If they use the same sumitomo/yazaki contacts, you can de-pin the contacts from your
current connector housings with a small jewelers screwdriver and re-pin them into the
other connector housings. No need to splice/solder anything.
edit: I recently spliced all new injector connectors into the harness on one of my shiros.
I found that the wires were brittle to the point of cracking when bent. Splicing in new
wires turned out to be the best solution. Unfortunately, the old retainers got tossed.
