Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/ID This Intake Manifold
Imported from Z31Performance.com Forums{{#if:mtherkamp| — original post by mtherkamp}}{{#if:2015-05-21 13:10:42|, posted 2015-05-21 13:10:42}}{{#if:12| · 12 post{{#ifeq:12|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/25045-id-this-intake-manifold.html|
mtherkamp: (2015-05-21 13:10:42)
How about a what is it? Game for those who know!
http://www.ebay.com/itm/87-96-VG30E-…12469f&vxp=mtr
What did this come from, will it fit the vg30et, and has anyone used it? Looks like a plastic upper, perhaps help with heat soak?
Here is another one, this time all aluminum, but looks like same basic design?
http://www.ebay.com/itm/83-89-VG30-N…7e1858&vxp=mtr
The bonus round is, with they fit under the stock hood? Looks potentially like a more compact version of the Frontier manifold, better flow I wonder?
Other thoughts?
nater86zx: (2015-05-21 14:56:28)
[archived image: Raisins_Face.jpg]
Interesting.... it looks as tall as the Frontier/Pathfinder manifold, but like you said more compact.
jaqattack02: (2015-05-21 15:03:26)
The only one's I've seen that are plastic are the one's that came on the mini-vans.
If it's really from a VG30E, then it will fit an ET just fine. No difference in the manifolds between them. Just depends on if that one needs a specific LIM or not.
mtherkamp: (2015-05-21 16:26:01)
I'm thinking its gonna be pretty friggen tall, just really an interesting deal.
Axel kain: (2015-05-21 17:20:18)
listing shows it comes with the LIM. the question is injector capabilities.
NissanEgg: (2015-05-21 20:45:56)
Black plastic type is a Villager/Quest setup.
Not sure what the second one in aluminum is. Need more pics to see the rest of the upper.
G-E: (2015-05-21 21:54:12)
Both minivan, and they fit backwards on the engine, so the throttle would be next to the z31 battery…
I expect more hood clearance issues than a stock pathfinder style, but less than the pathfinder's installed backwards…
mtherkamp: (2015-05-22 12:56:21)
^^ ah, never thought about the orientation! I knew someone would be able to shed light on these!
Axel kain: (2015-05-22 13:25:11)
if the lower is the same design as ours, flipping it to sit like a truck intake would be pretty easy.
G-E: (2015-05-22 13:34:19)
And what do you do about the distributor that you just decapitated?
mtherkamp: (2015-05-22 13:50:21)
I guess that's a good excuse for coil packs with crank trigger!
Rick88ss: (2015-05-22 16:41:12)
Fail
