Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/HELP removing distributer rotor
Imported from Z31Performance.com Forums{{#if:samshadow| — original post by samshadow}}{{#if:2013-11-16 22:28:29|, posted 2013-11-16 22:28:29}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/22951-help-removing-distributer-rotor.html|
samshadow: (2013-11-16 22:28:29)
So my Z is saying bad crank angle sensor. Took off cap and tried to remove rotor but it wont budge. Has anyone got any tips on removing the rotor? Besides removing screw?
mizagyu: (2013-11-16 22:31:39)
buy a new rotor, take vices grips and rip the old one off. if its stuck on, then it probably is old enough to need replacement.
samshadow: (2013-11-16 22:33:33)
yeah it's very stuck. Thanks
Hardway: (2013-11-17 04:03:27)
I am not sure about all 300zx's but all my '87 and '88's have a small bolt holding the rotor on. Look under the rotor hat on the shaft there may be bolt. If not, vise grips and destroying it may be your only option.
Kingman: (2013-11-17 14:30:09)
"Besides removing the screw?" Yeah man, probably best to buy a new rotor. They're cheap.
Axel kain: (2013-11-17 14:52:31)
You do also know the CAS is below the rotor and the cover plate? why not just replace the dist. or are you going to put in a later model (maxima) CAS pickup?
samshadow: (2013-11-17 18:38:01)
was going to just replace CAS since my Z is throwing the code. Yeah got it off with heat gun and vice grips.
