Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/Getting New Tires.
Imported from Z31Performance.com Forums{{#if:NissanXRMA| — original post by NissanXRMA}}{{#if:2010-03-28 16:27:44|, posted 2010-03-28 16:27:44}}{{#if:26| · 26 post{{#ifeq:26|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/9987-getting-new-tires.html|
NissanXRMA: (2010-03-28 16:27:44)
Okay so i need tires for the Riken 16x8" for it to fit in wells. These are the tires on it right now. 255/50/16
[archived image: DSC03609.jpg]
[archived image: wheels.png]
The tires need to be scaled down.
I was thinking of 225/50.
I was also thinking of 205/50. I really don't want much of a stretch at all. Maybe the littlest if i have to to fit them.
By the way wheels will be polished and the centers gloss black.
TurboDreams: (2010-03-28 18:17:54)
Is 205 even considered a stretch for 8 inch width wheels? I know its ungodly wide on 6 and 6.5 inch wheels I'd probably go for 225 though, wide is good.
NissanXRMA: (2010-03-28 21:18:42)
Bump. Anyone's opinion?
supertoad120: (2010-03-28 21:50:48)
I wouldn't go any narrower than 225's, but that's just me. I actually want to replace my 225/50's in the rear with 255/50's to get a little more rubber on the ground.
NissanXRMA: (2010-03-28 22:07:35)
My 255/50's are too big for my situation. I'd sell em to you if you were close for a good deal. They're practically brand new.
NissanXRMA: (2010-03-29 00:25:04)
Decided to go with Dunlop 215/45/16
Thanks for ALL the comments. Really helped the decision.
85z31t88: (2010-03-29 00:40:16)
just saw this post… I have 215/55r16 falkens going on my 16x8 bbs wheels. (this size is the correct size so the speedo wont change)
[archived image: Photo0081-1.jpg]
215/45r16's are going to be too small. They measure close to 23.5" tall. Stock tire height is right around 25". Your speedo will read faster than you are actually going.
check this website out:
http://www.rimsntires.com/rt_specs.jsp
NissanXRMA: (2010-03-29 00:45:55)
I'm sorry, I mean't 215/50.
They're about 24.4 inches tall.
vagabond: (2010-03-29 00:47:16)
225/45/16 .
No Smaller
85z31t88: (2010-03-29 00:51:04)
225/50r16, stock tire size
NissanXRMA: (2010-03-29 00:54:39)
So not 215/50? I need a pretty low profile tire to clear.
vagabond: (2010-03-29 01:00:07)
My front are 225/50/16 and fit fine.
85z31t88: (2010-03-29 01:01:05)
check out the website i posted above and decide what is right for you. Enter the tires you have on the wheels now with offset, and use the deal to figure out what you need to clear. It will give you dimensions and everything using offset.
85z31t88: (2010-03-29 01:01:58)
215/50's will work, but your speedo will be off some.
NissanXRMA: (2010-03-29 01:02:22)
My wheels also have a negative offset of -5 and have IC piping to get around, and to clear the fender.
NissanXRMA: (2010-03-29 01:02:57)
I dont care about the speedo. It will be off at 60 mph, like a few mph.
Leegamer: (2010-03-29 01:03:44)
Won't it also be affecting your odometer, as well? That shit will add up over time.
NissanXRMA: (2010-03-29 01:04:25)
Yeah thats the problem with my truck, it was off from the factory. I think diff trans speedo gear.
NissanXRMA: (2010-03-29 01:06:08)
Yeah, at 60 it will be off 1.1 mph. Not a big deal at all.
85z31t88: (2010-03-29 01:06:54)
You have the wider fenders and have a -5 offset. I have the narrower 85 fenders and my wheels have a -8 offset. You should be able to run a little wider tire than me because of the fenders.
With that said you should be fine with either any 215/50-55 or 225/45-50 tire.
NissanXRMA: (2010-03-29 01:08:18)
215/50's have been bought. More info later on the members rides. On the back, with 255/50's, there is a ton of overhang. So this will help.
85z31t88: (2010-03-29 01:09:29)
[archived image: Image003.jpg]
215/55r16 on a 16x8 wheel with -8 bs narrower 85 fenders.
vagabond: (2010-03-29 01:11:03)
my offset after the spacer is around 27mm.
- Ah I see you already ordered.
NissanXRMA: (2010-03-29 01:14:14)
255/50/R16 on 16x8" Riken +20 offset with 1" spacer. About -5 effective offset.
[archived image: 087.jpg]
85z31t88: (2010-03-29 01:17:40)
Perfect on the rear, flatten the inner fender lip and it will be fine. Camber increases as the tire goes into the fender.
I also see that you ordered already, just tryin to help out…
NissanXRMA: (2010-03-29 01:20:01)
No, I definitely appreciate the help. Especially since were going through the same situation. Thanks. :-)
