Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/Alternator Replacement.
Imported from Z31Performance.com Forums{{#if:'84z31| — original post by '84z31}}{{#if:2013-11-16 22:46:45|, posted 2013-11-16 22:46:45}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/22952-alternator-replacement.html|
'84z31: (2013-11-16 22:46:45)
I just finished replacing the alternator in my '84z and decided to look at the brochure that came with the reman-one. It said that if I had the capacitor equipped on the old alternator that I need to remove it and place it on the new one. Is this correct? What happens if I don't place that part on the new alternator? If I have to place the part on the alternator where can I find new caps?
flatfoot: (2013-11-17 04:28:29)
Its there for noise suppression. So you don't hear a whine from your alternator through your speakers.
You can run without it, but you may have a high pitched whine comming through the radio all the time.
Replacement parts are easy, Ebay alone turned up several for under $5, not to mention the parts houses and stereo stores.
862sik: (2013-11-17 05:27:22)
Just mount it on there. I don't think I kept mine…and I have a amp and I have no whine. I now use the vg33 quest alternator.
