Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/86t timing with early 87 crank pulley
Imported from Z31Performance.com Forums{{#if:Sharpen047| — original post by Sharpen047}}{{#if:2016-06-09 17:51:02|, posted 2016-06-09 17:51:02}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/531092-86t-timing-with-early-87-crank-pulley.html|
Sharpen047: (2016-06-09 17:51:02)
Hey guys, im trying to check the ignition timing on my z, its an 86t and has an early 87 crank pulley with different marks on the crank.(for using a titan alternator with the a/b series engine) the timing cover with the pointer is from my stock 86 stuff. is the 87 one in a different spot? the timing doesnt even show in the marks. the marks end up around 10 o clock on the pulley.
any help would be great. thanks.
88sinZ: (2016-06-10 01:21:24)
your further most LEFT mark is 0° each mark is a 5° BTDC increment.
If they don't line up you're ether not near TDC or your timing is off.
shromy: (2016-06-10 11:56:44)
probably 180 out. 2 crank revolutions for 1 cam revolution.
