Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/86 Turbo Wheel Spinners
Imported from Z31Performance.com Forums{{#if:jagalfaowner| — original post by jagalfaowner}}{{#if:2015-02-16 00:36:35|, posted 2015-02-16 00:36:35}}{{#if:10| · 10 post{{#ifeq:10|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/24743-86-turbo-wheel-spinners.html|
jagalfaowner: (2015-02-16 00:36:35)
How do I stop the star shaped Hub Caps / Spinners from moving. I can align them correctly and when I get home they are all moved. I thought about tape but realized they connect to the Wheel and not the Hub?
What have other people done other than replace their Wheels as I want to keep mine as original as possible. Maybe a small disk or rubber punched in against the back to cause the prongs to spread out?
Al
frostvectron: (2015-02-16 04:07:33)
There is supposed to be a small notch on one of the points of the star, and a corresponding notch on the wheel.
PrideZ31: (2015-02-16 15:15:43)
Seriously? I have to find said notch. Stupid thing drives me crazy because it moves and makes a little "click" every rotation.
reddzx: (2015-02-16 16:40:03)
keep in mind the 86 turbo and 86 NA center caps look very similar but are not the same size. I can't remember which but one fits both but is loose on the wrong one
amreboot: (2015-02-16 16:48:12)
On one wheel from my Titan, most of the plastic tabs broke off of the center cap.
I just put 2-3 dabs of RTV and put it back on. Using that little amount will definitely hold it on there, but will allow me to take it off if I need to.
Maybe a suggestion.
jagalfaowner: (2015-02-16 22:28:43)
I will look for the notch. The spinners on my Wheels are the same as for the AE. The NA are smaller as I got a set from EBay and they do not fit. The ones on it are original from when I bought it in 2005. If I use the Black Silicone, will it break the tip or prong when I remove it? IT a great idea as longs as I can remove , clean and replace?
frostvectron: (2015-02-17 03:53:40)
If it spins around, the bump on the cap must be worn down or broken. The notch on the wheel is still there though. I would just a get JB-weld and put a little glob where the old notch used to be. Let it dry then install it making sure your jb-weld bump fits into the notch in the wheel.
PrideZ31: (2015-02-17 16:43:27)
Ha, I guess those are the kind of things you learn from owning many Z's.
adamvann3: (2015-02-18 03:38:12)
I heard buying new wheels will resolve this issue [archived image: smile.png]
jagalfaowner: (2017-04-08 02:59:58)
Figured it out. I cut a 1 inch piece of tie wrap (like wrapped around a loaf of bread or trash bag, with a thin wire in it). I glued it to the tab on the spinner. An hour later I slipped it on the wheel. They do not move, are removed easily and do not rattle.
Al
