Forums/Z31P/z31-basics basic-modifications-basic-questions-aka-the-newbie-forum/300ZX Light Bar (Center Light) Modification Questions
Imported from Z31Performance.com Forums{{#if:daniel_pearce| — original post by daniel_pearce}}{{#if:2016-09-28 22:49:32|, posted 2016-09-28 22:49:32}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/basic-modifications-basic-questions-aka-the-newbie-forum/532545-300zx-light-bar-center-light-modification-questions.html|
daniel_pearce: (2016-09-28 22:49:32)
I read the write-up on Xenon's website on how to illuminate the center light on the 300ZX at night. However, I'm left with a few important questions.
1) What's the best tool to use to trim the backing in order to fit the fluro light?
2) What grit sandpaper should I use to sand the lettering down? 1000?
3) Where's the best place to buy fluorescent light cover, and how much should I buy?
4) Where's the best place to buy the aluminum for the backing, and how much should I buy?
5) The 300mm CCFL-Red is out of stock at Jaycar electronics. What's a good substitute? There's one made by Sunbeam here: http://www.moddiy.com/products/Sunbe…%252d-Red.html Would that be sufficient, or is there a better CCFL?
xenonxiii: (2016-09-29 22:14:37)
personally with all the LED options out there now I would Look into some Ultra bright LEDS instead of the Tube.
daniel_pearce: (2016-09-30 04:59:09)
Do you have a specific recommendations? What about the aluminum backing and fluorescent light cover? I noticed the aluminum backing looked black in the write up.
xenonxiii: (2016-10-04 04:11:42)
I would do the rest the same as the write-up. The light cover you can get in a sheet from any Big Box hardware store (home depot, lowes, Ace)
