Forums/Z31P/Cx racing intercooler and radiator kit
Imported from Z31Performance.com Forums{{#if:Willard| — original post by Willard}}{{#if:2017-05-26 02:03:58|, posted 2017-05-26 02:03:58}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/frequently-asked-questions-faqs/535848-cx-racing-intercooler-and-radiator-kit.html|
Willard: (2017-05-26 02:03:58)
I'm currently installing the radiator and I can't figure out how to mount it. If anyone has any experience with the cx racing kit it would help a bunch
NissanEgg: (2017-05-26 11:56:41)
Best of luck. They do not offer instructions on how do it nor are they willing to help you out if you try to contact them.
V8srfun: (2017-08-05 21:30:41)
Any updates on how this worked out
FrozenZ: (2017-08-06 19:15:36)
The CX Racing kit looks like a garbage design, the IC is basically in the worst place possible. You just gotta accept that your intercooler install will be custom. Go front-mount and don't overthink the pipe sizes because unless you're going huge, in which case you shouldn't need this advice, you are going from a 2" turbo outlet to a 54 or maybe 60mm throttle body so there's no point trying to ram 3" IC piping in there. You can either holesaw through the wheel well which makes it a no-brainer, or go over the top of the rad if you have gone with an efan (Even with a big 3-row rad you just have to clip a little bit from the center nose bracket thing to make room for 2" pipe over the rad, and people with smaller rads can get 2.5" over there.)
