Forums/Z31P/86 n/a wont drive
Imported from Z31Performance.com Forums{{#if:Snapplecrack| — original post by Snapplecrack}}{{#if:2016-12-06 06:41:32|, posted 2016-12-06 06:41:32}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/frequently-asked-questions-faqs/533620-86-n-a-wont-drive.html|
Snapplecrack: (2016-12-06 06:41:32)
As topic states my 86 n/a manual will not drive when i depress the clutch. loud thump/bang noise comes about where your elbow rests. new here to the fourms sorry if not in the correct location. i have searchs other threads and couldnt find my specific problem.
mtherkamp: (2016-12-07 13:45:34)
Sounds like a clutch issue, you will have to pull the transmission to inspect for broken or worn parts. When you say it won't drive, will it not go into gear? Will it go into gear with the engine off? We need more details on what exactly it is doing or not doing.
Snapplecrack: (2016-12-07 18:53:15)
Goes into gear, wont take off. The inly way the sound doesnt happen is when my clutch is pressed in
Snapplecrack: (2016-12-07 18:55:21)
Yes goes into gear with engine off.
mtherkamp: (2016-12-08 13:19:12)
Yep, definitely either a clutch or transmission issue. Have you tried to get it to move in all the gears, ie not just 1st? If it won't move in any gear, then it pretty much has to be a clutch issue. Regardless you are going to have to drop the trans and take a look at the clutch, pressure plate, flywheel, and throwout bearing.
