W series crank pulley on a/b crank.
  • W series crank pulley on a/b crank.
    I have been searching this for a couple hours and have not come up with defiant answer. Every thing i have read is that it should work with a longer bolt. Can any one confirm this?
    86na2t + holset
    feedback
    viewtopic.php?f=18&t=6114&hilit=andrew+gardner
    Anyone?
    86na2t + holset
    feedback
    This describes putting a A/B-crank pulley on a W-Crank… not the other way around....
    http://z31.com/wiki/doku.php?id=resources:w-series
    Crankshaft, Pulley, Bolt, and Washer
    Description
    The crankshaft front tip was lengthened by 18.7 mm (0.736) in. The crankshaft pulley width was increased by 13.6 mm (0.535 in.). There are now two keys instead of just one.
    Identification Additional Info
    Nissan made a spacer to allow you to fit the older A/B series crank pulleys to the W series cranks. The part number is 12308-V5321
    http://z31.com/wiki/doku.php?id=resourc … c_balancer
    This said it should work. I did some more searching today and found a post from butter saying he used a used a w series pulley with the ab crank on his cressida. I am going to try it and see what happens.
    86na2t + holset
    feedback
    I finished bolting everything up this morning and it works. I swapped the power steering pump, water pump pulley, and crank pulley from an 88 NA. I did have to buy a new crank bolt as the one from the 86 na was to short and the one from the 88na was the wrong diameter. The bolt i used was fastenal pn 11114730. m12x1.25x100 10.9 grade.
    86na2t + holset
    feedback
