VG30DE Build
  • #16
    money is no option, how about a big block hemi out of a funny car! or a 1000ci v8
  • #17
    Now we're talkin. Reminds me of this old caddy 500 we bored out… That thing was fucking brutal…
    Someone buy my mustang so I can get another zx…
  • #18
    How much power are you looking for? Let's start there.
    Shiro #443
  • #19
    I bet a couple of SR20's will pull a premium a week before Race Wars…
    2001 Mazda Miata LS
    also a 1989 Nissan 240SX
    50th AE Build Thread SOLD 2015
  • #20
    yes i did notice the DE motor and z32 in his write up. i didnt think there was that much difference between the two as far as horsepower.. so like if russ did all he did to the vg30 to the DE how much more horse are we really talking? enough to make a damn difference?
    86 NA auto 2+2 with 300k miles, now turbo with 5 speed
  • #21
    My buddy has a 92 NA Z32 with the biggest NA JWT cams and springs, UR pulley, APS light weight segmented flywheel, stock rods and pistons, Stillen headers, no cats, HKS hi-power exhaust, Z1 ecu tune, JWT pop-charger air filter, AIV and EGR delete, PCV reroute, AC and PS delete, fresh timing belt/oil pump/water pump and only makes 219whp. That's on stock bottom end and original headgaskets with 237k miles on the engine and has a small oil consumption problem. Add all the prices above to see if you want to go thru the hassle of building a DE NA motor and still be slower than a Z31 turbo or NA2T with a boost controller.
    1986 300ZX Turbo…sold
  • #22
    kontera wrote: Money is not an issue.
    THEN WHY DO YOU HAVE A Z31?
    kontera wrote:
    I want to go all motor
    Then you bought the wrong car. Goddamn ricer.
    My DD Civic Si is all motor! MAD TYTE! VTAKATAK!
    1985 Nissan 300ZX 2+2- My first Z, back in the family
    1987 Nissan 300ZX Turbo RIP 4/87 - 4/28/2011
    Under Construction: 1986 Nissan 300ZX NA2T Slicktop
    Originally posted by Tempestas
    Well, one of the t-tops wasn't latched real well… God only knows where that t-top flew off to at 150+ mph. Didn't scratch the car or anything, just a boom and it was gone. I sure as hell didn't stop to see where it went. I didn't see any stories on the news… so that's a plus.
  • #23
    YOUR VTAKKKKK GOES "BWWWWWWWWWWWAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAHHHHHHHHHHH"
    2001 Mazda Miata LS
  • #24
    forge the bottom, all as light as possible, and balanced as much as possible and 13-1 on pump gas, if you can spend alot more on the fuel system go alcohol, and 15-1 compression… than porting and polishing, large amounts of porting and polishing, don't skimp there, and the oversized valves will help alot… huge cams, stud everything, full ignition upgrade (super hot coils), stand alone engine management, custom intake manifolds, equal length large diameter runner headers (maybe even stepped, to save torque, and build the high hp), then feel the rush of 300+ whp then spray the ever living hell out of it...... If you spent all the same amount, then add 1500 for a good turbo, 700+ all day long..... with no spray, to each his own...... almost forgot, if you spray nitrous, some would say to stay away from alcohol for fuel, as it would be too much cooling to rapidly of the cylinders....... the more you do the less streetable it will be..,..a z31 with a sohc turbo could beat the pants off the vg30de with no nitrous..... with the built de, and stock long block sohc turbo..... but you would be unique as all get up!! good luck with whatever you do....
  • #25
    stprasinz wrote: forge the bottom, all as light as possible, and balanced as much as possible and 13-1 on pump gas, if you can spend alot more on the fuel system go alcohol, and 15-1 compression… than porting and polishing, large amounts of porting and polishing, don't skimp there, and the oversized valves will help alot… huge cams, stud everything, full ignition upgrade (super hot coils), stand alone engine management, custom intake manifolds, equal length large diameter runner headers (maybe even stepped, to save torque, and build the high hp), then feel the rush of 300+ whp then spray the ever living hell out of it...... If you spent all the same amount, then add 1500 for a good turbo, 700+ all day long..... with no spray, to each his own...... almost forgot, if you spray nitrous, some would say to stay away from alcohol for fuel, as it would be too much cooling to rapidly of the cylinders....... the more you do the less streetable it will be..,..a z31 with a sohc turbo could beat the pants off the vg30de with no nitrous..... with the built de, and stock long block sohc turbo..... but you would be unique as all get up!! good luck with whatever you do....
    Wow…Please…Stop…Now…
    The bullshit stops, when the GREEN light drops.
    Only babies cry about the bottle.
  • #26
    [quote="ZFast88ZWow…Please…Stop…Now…
    what'd I do wrong,
    not be a sarcastic stick like you? Not make comments of spending outlandish amounts of cash so I make reasonable things to do to the build for it to work well, not mock him? which of the things did I lack doing the most? I thought these forums were here to help people, not make them feel alienated..... Are you a car guy, and just always a dick, or only when someone wants to do something unique??? For some reason this is the road he decided to travel, so encourage it, not discourage…
  • #27
    If that's the case then
    kontera wrote:
    . Its simple.
    http://www.crateenginedepot.com/stor…P2382C509.aspx
    Make it fit.
    <style>.ig-b- { display: inline-block; }
    .ig-b- img { visibility: hidden; }
    .ig-b-:hover { background-position: 0 -60px; } .ig-b-:active { background-position: 0 -120px; }
    .ig-b-v-24 { width: 137px; height: 24px; background: url(http://badges.instagram.com/static/images/ig-badge-view-sprite-24.png) no-repeat 0 0; }
    @media only screen and (-webkit-min-device-pixel-ratio: 2), only screen and (min--moz-device-pixel-ratio: 2), only screen and (-o-min-device-pixel-ratio: 2 / 1), only screen and (min-device-pixel-ratio: 2), only screen and (min-resolution: 192dpi), only screen and (min-resolution: 2dppx) {
    .ig-b-v-24 { background-image: url(http://badges.instagram.com/static/images/ig-badge-view-sprite-24@2x.png); background-size: 160px 178px; } }</style>
    <a href="http://instagram.com/loganayotte?ref=badge" class="ig-b- ig-b-v-24"><img src="//badges.instagram.com/static/images/ig-badge-view-24.png" alt="Instagram" /></a>
  • #28
    hes not questioning which motor to build. he's wondering what to do to the vg30de. If he already has the enigne and feels money is no object, to what extent? if it truely is unlimited, what zfats said with all the titanium one off stuff would be the way to go, but I think more reasonable itmes might be the way to go.....
  • #29
    [quote]stprasinz wrote: [quote="ZFast88ZWow…Please…Stop…Now…
    what'd I do wrong,
    not be a sarcastic stick like you? Not make comments of spending outlandish amounts of cash so I make reasonable things to do to the build for it to work well, not mock him? which of the things did I lack doing the most? I thought these forums were here to help people, not make them feel alienated..... Are you a car guy, and just always a dick, or only when someone wants to do something unique??? For some reason this is the road he decided to travel, so encourage it, not discourage…[/quote]
    no one knows what zfast is…
    build it and spray it
  • #30
    three pages and i doubt broseph is gonna do anything at all
    kontera wrote:
    Hell yeah. Ill get my racing buddies
