Forums/Z31P/z31-repairs-forums driveline/overhauling cv axle…non turbo
Imported from Z31Performance.com Forums{{#if:mcx| — original post by mcx}}{{#if:2016-10-02 00:07:49|, posted 2016-10-02 00:07:49}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/driveline/532587-overhauling-cv-axle-non-turbo.html|
mcx: (2016-10-02 00:07:49)
I disassembled the rear drivers n/a cv axle because the boot split and grease was everyplace…i removed the c clip and slid the three roller bearing off the shaft…i didn't realize the shaft and bearing were supposed to be "marked" with paint to to reassembly in the same positioning? I suppose it matters so they don't bind.. anyone have a pix of a complete cv without the boots? is the inner bearing offset compared to the outer bearing? Thx,Mike
88sinZ: (2016-10-03 02:32:10)
just to clarify, you disassembled one side of the driver side shaft?
If so just put it back together, it will be fine.
frostvectron: (2016-10-04 21:11:27)
If I recall correctly, the inner and outer bearing ("tripods") should be offset from one another.
mcx: (2016-10-06 15:26:11)
Thanks for the replies…I ended up aligning both tri-pod bearings in the same position …i wiggled/contorted them around and it didn't bind on the work bench so installed them that way....took it for a drive and it was fine.
daniel_pearce: (2016-10-08 17:58:05)
Where did you get the new boot from?
maxBirdy: (2016-11-28 22:56:38)
if you didnt put it together exactly as it came apart, you now unbalanced it and it will shake the rear end.
